Deletes one or all proxy ARP entries.
| ipNetmask | Specifies an IP address/mask length. |
| ip_addr | Specifies an IP address. |
| mask | Specifies a subnet mask. |
| vr_name | Specifies a VR name. |
| all | Specifies all ARP entries. |
If you do not specify a VR or VRF, the current VR context is used.
When the mask is not specified, the software assumes a host address (that is, a 32-bit mask).
The following command deletes the IP ARP proxy entry 100.101.45.0/24:
configure iparp delete proxy 100.101.45.0/24
